UltiMaker S series printers can be connected to a network. This enables features such as remote printing and monitoring. You can connect via an Ethernet cable or via Wi-Fi. During the welcome setup of the S series printer, you will be prompted to set up a network connection. This can also be done later after completing the welcome setup.
Tip: The network status and connection processes are found in the Network menu in the Options overview (gear icon) on the printer.
Ethernet
To connect your printer via the Ethernet cable, simply connect one end of the cable to the port at the back of the printer, and the other side to a network source (router, modem, or switch).
Wi-Fi
To connect your printer to a wireless network, you will need a computer or smartphone.
Wait until your UltiMaker S series printer has created a Wi-Fi hotspot. This can take a minute. The name of the network is shown on the display. Use your computer or smartphone to connect to it.
A pop-up will appear on the display of your computer. Follow the steps to connect the printer to your local Wi-Fi network. The pop-up will disappear when you have completed these steps.
Tip: If you skip the Wi-Fi setup during the welcome setup, or if you want to connect to a different network later, you can always rerun the Wi-Fi setup. In the Options menu (gear icon), select Network and then Start Wi-Fi setup.
Note: Some UltiMaker S series printers experience problems with the Wi-Fi setup, especially when using a smartphone. This process will be updated in a future firmware version for greater reliability. In the meantime, see the articles below for additional information and workarounds.
Visit these pages for more information about setting up a network connection:
How to connect your printer to the network Network configuration and static IP
Firmware
When the network connection is successful, in the next step of the welcome setup, the printer will check if the latest firmware is installed. If a new version is available, you will be prompted to download and install it. Learn more about the S series firmware here:
Digital Factory
The UltiMaker S series printers can be connected to your UltiMaker Digital Factory workspace, using your UltiMaker Account. This will give you access to unique features. Learn more about getting started with your workspace on this page:
Create your UltiMaker Account and Workspace
