UltiMaker S7 - Update the firmware
000002887
Periodically, a new version of the UltiMaker S7 firmware is released. To ensure that your UltiMaker S7 has the latest features, we recommend keeping the firmware updated. This can be performed on the UltiMaker S7 when connected to a network or via USB.
Tip: For the latest release notes, please check this page: UltiMaker S series firmware release notes
The most recent firmware versions for the Ultimaker S7 are 9.0.5 (Latest) and 9.0.3 (Stable):
Latest channel
Release date: July 9, 2026
Download firmware 9.0.5
Stable channel
Release date: July 29, 2025
Download firmware 9.0.3
Update via USB
If the UltiMaker S7 is not connected to a network, you can update the firmware via USB. Take the following steps:
  1. Download the firmware file via the link above.
  2. Place the firmware file (.swu) in the root directory of a USB stick.
  3. Insert the USB stick into the USB port of your printer.
  4. Open the Options menu (gear icon), go to Maintenance → Update firmware, and select the new firmware in the update menu.
Wait for the UltiMaker S7 to finish updating the firmware. The printer will restart.
Note: Never remove the USB stick and never power off the printer during the installation.
Update via the network
Connect the printer to the network via Wi-Fi or Ethernet in the Options menu (gear icon), under Network. If the printer is already connected to the network, it will show a prompt whenever a new firmware version becomes available. If you choose to postpone the update until later, take the following steps when you are ready to install the new firmware:
  1. Go to the Printer tasks, or open the Options menu (gear icon), and go to Maintenance → Update firmware.
  2. Select the Stable or Latest version, depending on your preferred firmware channel.
  3. Press Install to start updating the firmware.
Note: Never interrupt the network connection or power off the printer while the firmware update is in progress.
