ER31 - Print core heater error
1667338550363
The information in this article applies to UltiMaker S series printers, including the UltiMaker S3, S5, and S7.
A heater error on one of the print cores can occur when the print core fails to heat up. The printer is trying to heat up the print core, but the print core does not report an increase in temperature. The display will show which print core is affected.
The heater error can have several different causes, including the print core hardware, the profile settings, the environment, or the material quality.
Note: If this error occurs specifically with a CC print core in combination with certain glass or carbon-filled materials, please contact support. A change was recently implemented for the CC cores (25 to 30 W) for increased reliability with composite materials at higher temperatures.
Troubleshooting tips
If this error appears, please perform the following checks:
Replace the print coreCheck if the error message continues to appear in the same slot after swapping the print cores. If so the error is not specific to the print core; please check the other tips below. If the error is repeatable for just one print core, clean the connections as described below. If this does not help, there could be a problem with the thermal connection between the print core’s temperature sensor and heater. In this case, the print core should be replaced.
Clean the print core connections
Never touch the contact point at the back of the print core with your bare hands, as oils and grease can affect the connection. Clean the contact points on the print core and on the print head PCB with a cotton swab and >70% IPA.
Caution: Isopropyl alcohol (CAS nr. 67-63-0) is a hazardous, highly flammable substance. Keep away from heat, sparks, static discharge, and other potential ignition sources. Ensure good ventilation and avoid inhaling the vapor. Read the SDS from your IPA supplier to learn more about the risks and safety precautions or find more information here: Isopropyl alcohol (IPA) safety.
Check the silicone nozzle coverThe silicone nozzle cover must always be installed during printing. This cover protects the print cores from the cold airflow from the fans. Check the quality of the nozzle cover and replace it with a new one if it is damaged or worn.
Change print settingsA combination of print settings can also lead to ER31. When printing too fast, the print core could struggle to maintain the correct nozzle temperature. Try lowering the print speed. Alternatively, the airflow from the side fans could impact the nozzle temperature, especially on larger flat surfaces. Try a lower fan speed.
Check the environmentWhen the printer is in a very cold environment, this could have an effect on the heating efficiency of the print cores. Ensure that the printer is in an environment according to the recommended ambient conditions (15 - 30 °C). Also, ensure to keep the door(s) closed during printing.
Dry the materialFilaments that contain a lot of moisture could show difficulties for the heater to reach and maintain the required temperatures. Therefore it is important to always correctly store your material, and dry your materials before printing if they have absorbed moisture.
Need further support?
If the error continues to appear after performing all the checks and corrective actions listed above, please contact support. For the most efficient help, please share the following information:
  • When the error appears (during loading material, during printing?)
  • The printer's log files
  • Which materials are used
  • Print settings (or preferably an UltiMaker Cura project file)
  • The outcome of the attempted troubleshooting steps
Tip: It could be interesting to take a look at the temperature graph of the printer. This is accessible (for network-connected printers) by typing the IP address of your printer in a browser and selecting Temperature Graph, or using the direct link http://[IP address]/info/temperature.html. Run a test print with the graph active and take a screenshot after ER31 appears.
