Isopropyl alcohol (IPA) safety
000002870
Isopropyl alcohol, sometimes also referred to as isopropanol or IPA, is a cleaning alcohol. This can be used for cleaning several components of your UltiMaker 3D printer, such as the print core contact points and the flexible build plate. It is important to work safely with this substance.
Caution: Isopropyl alcohol (CAS nr. 67-63-0) is a hazardous, highly flammable substance. Keep away from heat, sparks, static discharge, and other potential ignition sources. Ensure good ventilation and avoid inhaling the vapor.
You can find the most relevant hazard and precautionary statements for isopropyl alcohol (general) below. Please always read the safety data sheet (SDS) from your isopropyl alcohol supplier to learn more about the risks and safety precautions.
Hazard statements
  • H225 - Highly flammable liquid and vapor
  • H319 - Causes serious eye irritation
  • H336 - May cause drowsiness or dizziness
Precautionary statements
  • P210 - Keep away from heat, hot surfaces, open flames, sparks. - No smoking.
  • P243 - Take precautionary measures against static discharge.
  • P261 - Avoid breathing mist, vapors, spray.
  • P271 - Use only outdoors or in a well-ventilated area.
Translations of H and P statements
Below, you can find translations of the Hazard and Precautionary statements in several (EU) languages:
DE - Deutsch (German)
  • H225 - Flüssigkeit und Dampf leicht entzündbar.
  • H319 - Verursacht schwere Augenreizung.
  • H336 - Kann Schläfrigkeit und Benommenheit verursachen.
  • P210 - Von Hitze, heißen Oberflächen, Funken, offenen Flammen sowie anderen Zündquellenarten fernhalten. Nicht rauchen.
  • P243 - Maßnahmen gegen elektrostatische Entladungen treffen.
  • P261 - Einatmen von Staub/Rauch/Gas/Nebel/Dampf/ Aerosol vermeiden.
  • P271 - Nur im Freien oder in gut belüfteten Räumen verwenden.
ES - Español (Spanish)
  • H225 - Líquido y vapores muy inflamables.
  • H319 - Provoca irritación ocular grave.
  • H336 - Puede provocar somnolencia o vértigo.
  • P210 - Mantener alejado del calor, de superficies calientes, de chispas, de llamas abiertas y de cualquier otra fuente de ignición. No fumar.
  • P243 - Tomar medidas de precaución contra las descargas electrostáticas.
  • P261 - Evitar respirar el polvo/el humo/el gas/la niebla/ los vapores/el aerosol.
  • P271 - Utilizar únicamente en xteriors o en un lugar bien ventilado.
FR - Français (French)
  • H225 - Liquide et vapeurs très inflammables.
  • H319 - Provoque une sévère irritation des yeux.
  • H336 - Peut provoquer somnolence ou vertiges.
  • P210 - Tenir à l’écart de la chaleur, des surfaces chaudes, des étincelles, des flammes nues et de toute autre source d’inflammation. Ne pas fumer.
  • P243 - Prendre des mesures de précaution contre les décharges électrostatiques.
  • P261 - Éviter de respirer les poussières/fumées/gaz/ brouillards/vapeurs/aérosols.
  • P271 - Utiliser seulement en plein air ou dans un endroit bien ventilé.
IT - Italiano (Italian)
  • H225 - Liquido e vapori facilmente infiammabili.
  • H319 - Provoca grave irritazione oculare.
  • H336 - Può provocare sonnolenza o vertiginid.
  • P210 - Tenere lontano da fonti di calore, superfici calde, scintille, fiamme libere o altre fonti di accensione. Non fumare.
  • P243 - Fare in modo di prevenire le scariche elettrostatiche.
  • P261 - Evitare di respirare la polvere/i fumi/i gas/la nebbia/i vapori/gli aerosol.
  • P271 - Utilizzare soltanto all’aperto o in luogo ben ventilato.
NL - Nederlands (Dutch)
  • H225 - Licht ontvlambare vloeistof en damp.
  • H319 - Veroorzaakt ernstige oogirritatie.
  • H336 - Kan slaperigheid of duizeligheid veroorzaken.
  • P210 - Verwijderd houden van warmte, hete oppervlakken, vonken, open vuur en andere ontstekingsbronnen. Niet roken.
  • P243 - Maatregelen treffen om ontladingen van statische elektriciteit te voorkomen.
  • P261 - Inademing van stof/rook/gas/nevel/damp/ spuitnevel vermijden.
  • P271 - Alleen buiten of in een goed geventileerde ruimte gebruiken.
PT - Português (Portuguese)
  • H225 - Líquido e vapor facilmente inflamáveis.
  • H319 - Provoca irritação ocular grave.
  • H336 - Pode provocar sonolência ou vertigens.
  • P210 - Manter afastado do calor, superfícies quentes, faísca, chama aberta e outras fontes de ignição. Não fumar.
  • P243 - Tomar medidas para evitar acumulação de cargas eletrostáticas.
  • P261 - Evitar respirar as poeiras/fumos/gases/névoas/ vapores/aerossóis.
  • P271 - Utilizar apenas ao ar livre ou em locais bem ventilados.
