Several UltiMaker 3D printers use a glass build plate. This includes the UltiMaker S6 (Glass variant), the UltiMaker S5, and the UltiMaker S3, as well as older printer series (UltiMaker 2 series, 3 series, and Original+).
UltiMaker glass build plates are made of high-quality tempered safety glass designed to withstand the thermal demands of 3D printing. However, like all glass products, they require proper handling.
This article contains information about handling the build plate, including installation, print adhesion and removal, and maintenance to ensure safe operation and reduce the risk of damage.
Main risks
If a glass plate is damaged or stressed, it can chip, crack, or shatter, presenting a risk of sharp edges and injury. These are the main factors that can cause build plate damage:
- Over-adhesion: Materials contract as they cool down, some more than others. If the print bonds too tightly directly to bare glass, it can pull shards of glass off the surface upon removal.
- Thermal shock: Sudden, extreme temperature changes (such as washing a hot plate under cold water, or placing a freezing cold plate onto a hot heated bed) can cause the glass to crack or shatter. This chance is bigger if there is already some damage (chips or cracks) to the plate.
- Impact: Sharp impacts to the edges or corners of the plate during installation, removal, or other handling can fracture the edges, which reduces the structural integrity of the plates.
Caution: Glass shards and edges of a damaged build plate are sharp and may cause injury. Always handle the glass build plates with care. Wear protective gloves and glasses if needed (see below) and carefully discard damaged build plates.
Build plate installation
The glass plate is installed on the heated build plate and held in place with the metal build plate clamps. Before installing the glass plate in the printer:
- Clear the plate: Remove the previous print, including the brim or skirt, and clean the surface (see details below).
- Check for damage: Closely inspect the plate for any signs of damage, such as chips in the surface or sharp corners. Do not use a damaged build plate, but discard it safely and carefully.
- Prepare the surface: Apply a new layer of adhesive, if required for the next print (see details below). While glue can be applied with the plate installed in the printer, an adhesion sheet or spray must be applied outside of the printer.
Take the following steps to install the glass build plate:
- Open the metal build plate clamps at the front of the Z stage.
- Slide the glass plate into the clamps at the back, while keeping the glass flat.
- Close the clamps at the front to secure the glass build plate.
Tip: If the build plate was prepared with an adhesive, make sure the adhesive faces up. When printing on bare glass, ensure the side with the warning sticker is facing up (this side is best for printing).
Adhesion methods
Most materials benefit from a layer of glue applied evenly to the glass build plate. This can help improve adhesion, reducing the risk of the print detaching during printing. However, for some materials (including ABS, PETG, and CPE), the glue also acts as a protective layer for the glass.
Caution: Printing on bare glass with these materials is likely to cause chipping of the glass build plate when the print is removed.
There are several adhesion methods that can help the print stay securely attached during the print, while protecting the glass plate surface, such as:
- Glue (e.g. UltiMaker UHU stick, 3DLAC Stick, or a specialized Magigoo)
- Spray (e.g. 3DLAC)
- Adhesion sheets (available for both UltiMaker glass build plate sizes, learn more here)
Tip: For an overview of which glue to use on the glass build plate for all UltiMaker materials, visit this article.
Removing the print
Always remove the print from the glass build plate safely and carefully to protect both the printed part and the glass plate. Using excessive force may cause damage or even injury. Mind the following for safe print removal:
- Let the build plate cool down completely after printing. Many prints will self-release or pop off naturally once the plate reaches room temperature, although this depends on the material(s) and adhesion method used and the size and shape of the print.
- Removing a print from a build plate that is still warm may not only be difficult, but it can also deform the print or burn your hands if the plate is too hot.
- If the print has not detached after cooldown, remove the plate from the printer. Never apply force to the build plate or printed part still inside the printer, as this may damage the metal build plate clamps.
- You can run cool to lukewarm water over the plate to dissolve the glue and detach the print, but mind the temperature difference. Don't run cold water over a hot build plate to prevent thermal shock. Don't use hot water to prevent injury and damage to the printed part.
- When using tools (such as a spatula or scraper) to pop off the print, apply force gently. It is advised not to use tools with sharp edges and to wear protective gloves.
Tip: For more information and tips about removing the print from the glass build plate, visit this article.
Cleaning and maintenance
After removing the print, prepare the glass plate surface for the next print job.
- Clear the plate: Ensure all prints and helper parts (skirt, brim, raft, supports) are fully removed from the glass build plate.
- Clean the plate: Do not let layers of glue build up. Clean the glass plate with water and, if needed, detergent, and use a non-abrasive sponge or brush. You can also use isopropyl alcohol (IPA)* to wipe down the plate.
- Dry the plate: Thoroughly dry the glass plate using a microfiber cloth. Never place a wet build plate back inside the printer.
- Inspect the plate: Run a quick visual check. If you notice any chips, deep scratches, or spiderweb cracks, discontinue use immediately and replace the plate.
- Reapply adhesion: See the recommendations for adhesion methods above.
Caution: Isopropyl alcohol (CAS nr. 67-63-0) is a hazardous, highly flammable substance. Keep away from heat, sparks, static discharge, and other potential ignition sources. Ensure good ventilation and avoid inhaling the vapor. Learn more here.
Protective gear
While daily printing and handling of an intact glass plate does not require specialized gear, we strongly advise wearing safety glasses and protective gloves in the following scenarios:
- Removing a print from the glass build plate that is severely overadhered or stuck.
- Handling, removing, or disposing of a build plate that is already chipped, cracked, or shattered.
