UltiMaker 2+ Connect: Set up for first use
1667411286768
After installing the hardware accessories, set up the UltiMaker 2+ Connect for first use. Turn on the printer with the power switch at the back. After booting up, you will see the home screen. This displays your printer's status and allows you to quickly navigate to the Materials, Settings, or Maintenance menus.
Note: It is possible that the UltiMaker 2+ Connect shows a firmware upgrade screen when it boots up for the first time. If this is the case, update the firmware by following the instructions on this page.
The setup consists of a few different steps:
Level the build plate
To get the correct distance between the nozzle and the glass build plate, the build plate must be leveled. The UltiMaker 2+ Connect offers a quick and assisted manual leveling procedure.
MaintenanceSelect the Maintenance menu on the touchscreen display and navigate to Level build plate. Follow the instructions on the screen, or visit this page for more information.
Load material
Before you can start printing on the UltiMaker 2+ Connect, you need to load material into the printer. For the first use, it is recommended to use the spool of PLA that came with the UltiMaker 2+ Connect, but other material types can be loaded as well. With the ergonomic feeder lever, loading material is easy.
MaterialsSelect the Materials menu on the touchscreen display and navigate to Load material. Follow the instructions on the screen, or visit this page for more information.
Set up a network connection
The UltiMaker 2+ Connect can connect to a network, using either Wi-Fi or Ethernet. This is optional but strongly recommended. First set up your network connection before adding the printer to your personal Digital Factory, to benefit from remote printing features.
SettingsSelect the Settings menu on the touchscreen display and navigate to Network configuration. Follow the instructions on the screen, or visit this page for more information.
Done! You are now ready to start printing.
