UltiMaker Cura interface overview
1667411132925
  1. Open file. Opens a 3D file.
  2. Printer selection panel. Displays the selected printer. You can also activate another added printer, add new printers, and manage your list of printers if you click here.
  3. Configuration panel. Contains the material and print core or nozzle setup. Manually select a different configuration if required, or choose from all available configurations for your connected UltiMaker 3D printers.
  4. Stages. The prepare, preview, and monitor stage. Each stage is arranged to efficiently go through each 3D printing step.
  5. Print settings panel. This panel contains the print profiles and all individual print settings.
  6. Marketplace. Contains plugins and material packages.
  7. App switcher. Easily visit UltiMaker's additional platforms for support, e-learning, and more.
  8. UltiMaker account. Sign in to your UltiMaker account or create a new one to gain access to cloud functionality, Marketplace plugins and print profiles, backups, and more.
  9. Action panel. Contains an action button dependent on the current stage. This can contain the button to slice the model, but other options are available once the model is prepared.
  10. Save or share file. After slicing, you can save the file to your computer or a removable drive, or directly start the print via local network. If you have UltiMaker printers connected to the Digital Factory, you can also print via cloud, or save the project to your Digital Library.
  11. Preview. Proceeds to the next stage, the Preview stage.
  12. Camera position tool. Easily positions the camera to one of the default viewing angles.
  13. Model information. Contains the print job name (based on the first model loaded) and the total dimensions of all printable models on the build plate. If there are multiple models, these are shown in the Object list.
  14. Adjustment tools. Move, rotate, mirror, scale, and more options to alter the appearance or orientation of your 3D model(s).
