The Material Station was unable to successfully unload the current material in the final unloading stage.
This could be due to:
- The filament is stuck in the system or decoupler
- The prefeeder of the Material Station is faulty
Note: It is important that the material profile is updated for compatibility with the Material Station. If this error occurs with a third-party material, get the latest update from the Marketplace. Printing with materials that are not optimized for compatibility with the Material Station can increase the likelihood of this error message.
To troubleshoot, please do the following:
Tip: For step-by-step instructions (including photos) on how to remove the broken PVA from the system, read the troubleshooting guide on this page.
- Note the bay number and extruder number indicated by the display.
- Power down the Ultimaker S5.
- Detach the power cable from the Material Station.
- Check the filament entry point at the front side of the Material Station at the noted bay and extruder.
- If the filament spool failed to unload completely, please continue to the next step.
- If the spool is completely unloaded and coiled loose on the spool, please contact your local service provider for assistance.
- Check the short tube at the back of the Material station; between the machine exit point and the decoupler.
- If the filament is visible at this location, but not visible above the decoupler, it means the filament is stuck in the decoupler. Please continue to the next step.
- If the filament is not visible at all at the back of the machine, it means the filament is stuck inside the system. Please continue to the next step.
- Gently push the stuck filament forward through the system until you see the faulty filament coming out of the Bowden tube at the back.
- Continue pushing until the new filament sticks out a few centimeters out of the Bowden tube at the back.
Tip: Always push loose filament forward through the system, never the other way around.
- Cut the currently loaded filament roll at the entry point of the Material Station
- Grab the end of the filament sticking out of the Bowden tube at the back and gently pull the remaining filament completely out of the system.
- Reattach the Bowden tubes to the feeder.
You can now reconnect the power cable to the Material Station, switch on the Ultimaker S5 using the switch at the back, and continue operation.
Need further support?
If the error persists, or you get stuck during the troubleshooting steps, please contact support for further assistance. Include the error number (ERXX) and your printer's log files for efficient troubleshooting.
