ER13 - Min temp. error on PrintCore
1667411295386
This error can appear on the UltiMaker 3 or 3 Extended and refers to a problem with the print core temperature. It indicates that the printer has registered a too low temperature in one of the print cores. This can be caused by the environment or the print core.
Environment
UltiMaker 3D printers are not intended to be used in very cold environments. During operation, always ensure that the environment is at least 15 °C (59 °F). At lower temperatures, the print core can show this min temp error, or have trouble heating up and maintaining the right nozzle temperature.
Print core
If the environmental conditions are correct, the problem could be caused by the connection of the print core. However, in that case, a max temp error would be more likely. Please follow the instructions on this page:
ER12 - Max temp. error on PrintCore
If that also did not help, there is probably an issue with the PCB at the back of the print core. This cannot be resolved, and the print core must be replaced.
