Ultimaker 2+ Maintenance kit
1667337573011
The Ultimaker 2+ Maintenance kit contains the most commonly used replacement parts for the Ultimaker 2+ or Ultimaker 2 Extended+. This kit optimizes your maintenance workflow and prepares you to quickly resolve most issues with your printer.
What’s included?
Below you can find an overview of all the parts that are included in the maintenance kit.
  1. 1x Glass plate
  2. 1x Bowden tube
  3. 1x PT100 B sensor
  4. 1x Heater cartridge
  5. 1x Grease
  6. 1x Machine oil
  1. 1x Calibration card
  2. 2x Build plate clamp
  3. 2x Clamp clip
  4. 2x Tube coupling collet
  5. 1x Hot end isolator
  6. 4x Olsson nozzles
    (0.4, 0.25, 0.6, and 0.8 mm)
  1. 2x TFM isolator coupler
  2. 1x Print head alignment aid
  3. 1x Hot end cooling fan
  4. 2x Print cooling fan
Tip: The instructions for the repair procedures of all parts included in the maintenance kit can be found on this page: Ultimaker 2+ repair manuals.
Maintenance schedule
To keep your Ultimaker 2+ in optimal condition, we recommend the following maintenance schedule, based on 1,500 printing hours per year.
Tip: You can find more information about the maintenance actions and instructions via this page: Ultimaker 2+ maintenance schedule.
Every monthEvery 3 monthsEvery year
Clean the printerCheck for play on the axlesClean the feeder
Lubricate the axlesCheck the tension of the short beltsLubricate the feeder gear
 Lubricate the lead screwCheck the Bowden tube
 Re-tighten the hot end isolator
Note: If the usage frequency is higher, please increase the frequency of maintenance on your machine to maintain optimal printing results.
