UltiMaker 2+ - Repair manuals
1667337572864
Most parts for the UltiMaker 2+ are not very difficult to replace. This page contains repair guides for the most commonly replaced spare parts in PDF format. You can download the instructions you need below.
Note: Because the UltiMaker 2+ is no longer supported, the availability of spare parts is not guaranteed. The items listed in the manuals may not be available anymore. Certain parts may have alternatives (including packs or assemblies) if these are common parts with still supported printers, such as the S series or 2+ Connect.
Maintenance Kit manuals
These are the repair guides for all parts in the UltiMaker 2+ Maintenance kit.
Most repairs are quite approachable.
Detailed repairs
The manuals listed below were originally intended for repair technicians.
Some of the procedures can be a little tricky.
Ultimaker 2+ repair manual - Bowden tube
Ultimaker 2+ repair manual - Build plate clamps
Ultimaker 2+ repair manual - Clamp clip
Ultimaker 2+ repair manual - Glass plate
Ultimaker 2+ repair manual - Heater cartridge
Ultimaker 2+ repair manual - Hot end cooling fan
Ultimaker 2+ repair manual - Hot end isolator
Ultimaker 2+ repair manual - Model cooling fans
Ultimaker 2+ repair manual - Nozzle
Ultimaker 2+ repair manual - PT100 sensor
Ultimaker 2+ repair manual - TFM coupler
Ultimaker 2+ repair manual - Tube coupling collet
Ultimaker 2+ repair manual - Display
Ultimaker 2+ repair manual - Fans
Ultimaker 2+ repair manual - Heated bed
Ultimaker 2+ repair manual - LED strip
Ultimaker 2+ repair manual - Mainboard
Ultimaker 2+ repair manual - Sliding blocks
Ultimaker 2+ repair manual - UltiController
