Here you can find the UltiMaker PPS CF TDS. The TDS applies to UltiMaker 2.85 mm material.
The technical data sheet contains the mechanical and thermal properties of 3D printed samples on the UltiMaker Factor 4. The mechanical properties are measured on 3D printed samples in three different orientations, after printing as well as after annealing.
Downloads
Note: The PPS CF TDS is currently only available in English.
PPS CF TDS - EN - English version 2024
