UltiMaker Nylon CF Slide TDS
UltiMaker-Nylon-CF-Slide-TDS
Here you can find the UltiMaker Nylon CF Slide TDS. The TDS applies to UltiMaker 2.85 mm material.
The technical data sheet contains the mechanical and thermal properties of 3D printed samples on the UltiMaker Factor 4. The mechanical properties are measured on 3D printed samples in three different orientations, after printing as well as after annealing.
EN - English TDS 2025
NL - Dutch TDS 2025
FR - French TDS 2025
DE - German TDS 2025
IT - Italian TDS 2025
ES - Spanish TDS 2025
