How does UltiMaker Nylon CF Slide compare to POM?
Nylon-CF-Slide-compared-to-POM
UltiMaker Nylon CF Slide is a great alternative to POM (polyoxymethylene) when used in e.g. complex shaped parts in machinery or production lines. Its high wear resistance and low friction results in great replacement parts with long lifespan that can withstand motion under high pressure and velocity. Below is a summary of the many characteristics where Nylon CF Slide serves as a good replacement. Specific data on the wear resistance and friction coefficient of Nylon CF Slide against steel and stainless steel can be found here.
POM
Nylon CF Slide
Max service temp (max load/long period)
100°C
180°C (HDT B, annealed) 114°C HDT A, annealed
Max service temp (low load/short period)
140°C
175°C
Tensile modulus
2800 MPa
4388 MPa (XY), 2362 MPa (Z)
Charpy impact
6 kJ/m2 (notched)
7 kJ/m2 (notched), 24 kJ/m2 (unnotched)
Coefficient of friction
<0.3
0.2-0.3
water absorption (70% RH)
approx. 0.5%
2.2%
Dimensional stability
Exceptional
Good
Wear resistance
Exceptional
Very good, >48h against stainless steel at high pv (pressure velocity)
Surface finish
Smooth, mostly white
Textured, black (smoother after post processing)
Chemical resistance
Excellent
Very good against industrial solvents and oils (lower against acids and oxidizing agents)
Nylon CF Slide can also be post processed in the same way as POM, for example using the following CNC settings:
material = POM
milling bit = Carbide 2-Flute End Mills 6mm
rpm = 15000
feed rate = 400 mm/min (6.6 mm/s)
plunge rate = 90 mm/min (1.5 mm/s)
cut depth = 2 mm
