Factor Series - User manual
Factor4-User-manual
The UltiMaker Factor Series user manual contains all the information to properly set up your new UltiMaker product and to start printing. The information on this page applies to the UltiMaker Factor 4 and Factor 4 Plus.
Tip: The UltiMaker Factor Series printers contain a quick start guide. This guide helps you quickly set up your new product for first use. If you no longer have this booklet, you can download a PDF (including translations): Factor 4 or Factor 4 Plus.
Disclaimer
This manual sets out the instructions on how to install and operate the UltiMaker Factor Series 3D Printer. Please read and understand the contents of this installation and user manual carefully. Failure to read the manual may lead to personal injury, inferior print results, or damage to the UltiMaker printer or its accessories. Always make sure that anyone who uses this 3D printer knows and understands the contents of the manual to make the most out of the UltiMaker printer.
Upon delivery of the product, installation shall be done in accordance with the instructions in this user manual. The handling, storage, use, and disposal of the device are beyond our control and are for your sole responsibility. We do not assume responsibility and expressly disclaim liability for loss, injuries, damage, or expense arising out of or in any way connected with the handling, storage, use, or disposal of the product.
The information within this document has been collected and represented with great care and is considered accurate. In case inconsistencies or inaccuracies are observed, those are unintentional, and UltiMaker welcomes being made aware of them. Submit your feedback to UltiMaker by creating a support case.
This installation and user manual is available in several languages. In case of discrepancies between the original English version and the translated text, the English version is leading. Please contact UltiMaker support if you notice any inaccuracies, or in case of questions or concerns.
Downloads
Note: The English version has been updated to include both Factor 4 and Factor 4 Plus. Translations are yet to be updated and will be added shortly.
EN - Factor Series User manual (Original version)
AR - Factor 4 دليل التثبيت والاستخدام
DE - Factor 4 Installations- und Benutzerhandbuch
ES - Factor 4 Manual de instalación y uso
FR - Factor 4 Manuel d’installation et d’utilisation
IT - Factor 4 Manuale di installazione e uso
NL - Factor 4 Installatie- en gebruikershandleiding
