UltiMaker PC TDS
UltiMaker PC TDS
1667410781512
Here you can find the Ultimaker PC TDS. The TDS applies to UltiMaker 2.85 mm material.
The technical data sheet is updated in April 2022 with additional mechanical and thermal properties of 3D printed samples on the UltiMaker S5 Pro Bundle. The tensile properties are measured on 3D printed samples in three different orientations.
Since the opaque (black and white) filament differs from the transparent filament, there are two separate technical data sheets available.
Note: The updated dual version of the PC TDS is currently only available in English. Previous translations can be found below.
PC black/white TDS version 2022 - EnglishPC transparent TDS version 2022 - English
Translations of previous TDS
NL - Dutch version 2017KO - Korean version 2017
DE - German version 2017NO - Norwegian version 2017
FR - French version 2017PL - Polish version 2017
IT - Italian version 2017PT - Portuguese version 2017
ES - Spanish version 2017DA - Danish version 2017
SV - Swedish version 2017CS - Czech version 2017
ZH - Chinese version 2017RU - Russian version 2017
JA - Japanese version 2017HU - Hungarian version 2017
TR - Turkish version 2017FI - Finnish version 2017
