Here you can find the UltiMaker ABS TDS. The TDS applies to UltiMaker 2.85 mm material.
The technical data sheet is updated in April 2022 with additional mechanical and thermal properties of 3D printed samples on the UltiMaker S5 Pro Bundle. The tensile properties are measured on 3D printed samples in three different orientations.
Note: The updated version of the ABS TDS is currently only available in English. Previous translations can be found below.
TDS version April 2022 - English
Translations of previous TDS
